I’m trying to offload SSL for metatrader 4 (and soon metatrader 5) software using LTM however I haven’t had any luck getting it working - does anyone have any experience getting this working? Right now I’m stuck using fastl4.
can you post the configuration you used for the SSL offload configuration? How did it fail when it wasn’t working (error messages, timeouts..)?
config is a generic 11.6 fastl4 vip, pool consists of one node with a tcp check.
when i tested i tried two configurations
1) standard vip + clientssl and serverssl profiles + http profile 2) standard vip + clientssl and serverssl profiles
i have limited knowledge of the inner workings of the application, however i can say that when running curl against the address over layer4 will result in a timeout while running at layer7 (either configuration) will result in a connection refused. when using telnet, all three configurations result in a “connection closed by foreign host” after pressing enter once. i don’t believe it’s technically https so curl shouldn’t work.
