Hello everybody,
The irule:
when CLIENT_ACCEPTED {
SSL::disable
when SERVER_CONNECTED {
log local0.info "New connection"
TCP::collect
when CLIENTSSL_HANDSHAKE {
log local0.info "HANDSHAKE"
when CLIENT_DATA {
set lcpayload [string tolower [TCP::payload]]
if { $lcpayload contains "starttls" } {
set tag [getfield [TCP::payload] " " 1]
TCP::respond "$tag OK STARTTLS completed\r\n"
TCP::payload replace 0 [TCP::payload length] ""
log local0.info "STARTTLS_DONE"
SSL::enable
} elseif { $lcpayload contains "logout" } {
serverside { TCP::collect }
} elseif { $lcpayload contains "capability" } {
log local0.info "capability command issued"
TCP::respond "$tag NO Mechanism not available\r\n"
TCP::release
when SERVER_DATA {
log local0.info "checking for CAPABILITY"
set index [string first "CAPABILITY" [TCP::payload]]
if { $index > 0 } {
log local0.info "replace CAPABILITY string"
TCP::payload replace [expr $index + 10] 0 " STARTTLS LOGINDISABLED"
clientside { TCP::collect }
log local0.info "No capability string"
TCP::release
This kinda works. Thunderbird is able to connect to the INBOX. But, if I try to open another mailbox, thunderbird hangs and status bar is showing message ‘Checking mail server capabilities…’
On the F5 side things are looking just fine:
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : New connection
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : checking for CAPABILITY
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : replace CAPABILITY string
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : capability command issued
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : STARTTLS_DONE
Oct 28 10:26:56 tmm tmm[1611]: Rule imap-starttls : HANDSHAKE
When tracing both the client and server sides I see that Tbird sends the capability command:
-1337352192[3abf240]: 4885a00:imap.utu.fi:NA:SendData: 3 capability
But the server never sees that.
I’m puzzled.
