Offline pool member still recieving traffic
Hi all,
I have recently set up a pool of WebLogic servers in our pair of 1600’s running v11.2.1 HF3. I have a health monitor in place and everything is working as expected for that part.
However, when an instance is downed, either by the health monitor or by disabling/offlining in the GUI, the instance still recieves traffic. The traffic only seems to stop once a config sync takes place.
Is there any additional caching that would be causing this behavior?
Any info or advice would be greatly recieved.
Thanks, Anthony
Are you sure it’s not just healthcheck traffic you are seeing? It’s expected to see continue to see healthcheck traffic from the non-floating self-ips after a check fails.
If you have disabled the pool member and not performed a config-sync, you would expect healthchecks cease from the Active device, however the standby would not stop checking until after the config-sync.
Do you have oneconnect and cookie persistence enabled on the vs?
Yep - so I reckon if you change to “Reselect” you’ll be able to turn oneconnect back on.
If you have L7 persistence (like cookies) and you have requests being made over shared HTTP Keepalive connections (such as would come from a corporate proxy) then you need oneconnect to examine each HTTP request within a TCP stream individually. If you don’t have persistence then you don’t ‘need’ oneconnect.
It’s also useful as it enables serverside connection re-use - you can hold open a pool of long-lived serverside connections and re-use them.
