I’m using this script (which is floating around in the forums):
!/usr/bin/perl
Usage: f5-bigip-tmm-cpu.pl
use Net::SNMP qw(:snmp);
my $host = $ARGV[0];
my $snmp_comm = $ARGV[1];
chomp $host;
chomp $snmp_comm;
my $tmmTotalCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.41.0';
my $tmmIdleCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.42.0';
my $tmmSleepCyl = '.1.3.6.1.4.1.3375.2.1.1.2.1.43.0';
my ($session, $error) = Net::SNMP->session(
-hostname => $host,
-community => $snmp_comm,
-port => 161,
-version => 'snmpv2c',
-nonblocking => 0
if (!defined $session)
print "Received no SNMP response from $host\n";
print STDERR "Error: $error\n";
exit -1;
poll CPU oids
my $polled_oids = $session->get_request(
-varbindlist =>
[$tmmTotalCyl, $tmmIdleCyl, $tmmSleepCyl] );
calculate CPU Utilization
my $tmm_cpu = (( $polled_oids->{$tmmTotalCyl} -
($polled_oids->{$tmmIdleCyl} + $polled_oids->{$tmmSleepCyl}))
/ $polled_oids->{$tmmTotalCyl} ) * 100 ;
Round to integer
$tmm_cpu = int($tmm_cpu + .5);
print CPU Utilization to stdout for cli validation
print $tmm_cpu;
The odd thing is that is seems to be giving me incorrect values. I’ve done some traffic moves recently that greatly reduced the TMM CPU usage on one of my nodes, and the Big-IP GUI has correctly noted the change in traffic as has tmstat. Currently the TMM cpu utilization is at about 10%, yet this script through cacti is giving me 54%.
what version TMOS are you running? This worked pretty well pre-9.4, but I had some issues as well afterwards, but have not gone back and looked at the mibs. I’ll add this to my to do list to validate the accuracy.
I borrowed pretty heavily from the original script, but I think I have a version that is a little closer to my reality. I read the docs and found that it needed to have an interval for a delta calculation to get the appropriate. After running this a few times it seems to be pretty much right on with the percentage of TMM CPU utilzation:
!/usr/bin/perl
($time,$idle,$sleep) = &getValue($host,$snmp_comm);
sleep(5);
($time1,$idle1,$sleep1) = &getValue($host,$snmp_comm);
$time_delta = $time1 - $time;
$idle_delta = $idle1 - $idle;
$sleep_delta = $sleep1 - $sleep;
$tmm_usage = (($time_delta - ($idle_delta + $sleep_delta)) / $time_delta )*100;
$tmm_usage = int($tmm_usage + .5);
print "$tmm_usage";
sub getValue {
my ($host,$snmp_comm) = (@_);
my $tmmTotalCycles = '.1.3.6.1.4.1.3375.2.1.1.2.1.41.0';
my $tmmIdleCycles = '.1.3.6.1.4.1.3375.2.1.1.2.1.42.0';
my $tmmSleepCycles = '.1.3.6.1.4.1.3375.2.1.1.2.1.43.0';
my ($session,$error) = Net::SNMP->session(
-hostname => $host,
-community=> $snmp_comm,
-port=> 161,
-version=> 'snmpv2c',
-nonblocking=> 0
if (!defined $session) {
print "Recieved no SNMP response from $host\n";
exit -1;
-varbindlist => [$tmmTotalCycles,$tmmIdleCycles,$tmmSleepCycles]
my $total_time = $polled_oids->{$tmmTotalCycles};
my $total_idle = $polled_oids->{$tmmIdleCycles};
my $total_sleep = $polled_oids->{$tmmSleepCycles};
return($total_time,$total_idle,$total_sleep);
ah yes, the delta, we did fix this a while back and I believe is included in the current cacti template, though certainly not as elegant as your solution.
