OCSP Stapling
I am starting to be asked by my customers if we can support OCSP stapling to improve SSL performance. Is this something that BigIP supports? I can’t seem to find any documentation that covers it on ask.f5.com…
thanks..
David.
Unfortunately no. The best recommendation I can give right now is to open a support case.
as kevin suggested, you may open a case to expedite the implementation.
ID385549 - RFE SSL: Support OCSP Stapling - RFC6066 TLS extenstion
have there been any updates to this?
it is targeted in 11.6.0.
Its in 11.6, now trying to figure out how to use it :slight_smile:
