Occasional TCL Errors for HTTP::method ?
We use the following at the top of our main HTTP iRules:
when RULE_INIT {
set sec_http_versions [list “0.9” “1.0” “1.1” ]
set sec_http_methods [list “GET” “POST” “HEAD”]
if { ![matchclass [HTTP::version] equals $::sec_http_versions ] } {
reject
if { ![matchclass [HTTP::method] equals $::sec_http_methods] } {
reject
(rest of the iRule goes here)
I’m pretty sure we snagged that from an F5 DevCentral newsletter awhile back.
Anyway, recently, we have started getting the following messages sporadically in the TMM logs:
Oct 16 01:01:30 tmm tmm[1120]: 01220001:3: TCL error: Rule poolpicker - Not found. Invalid server side API (line 1) invoked from within “HTTP::method”
Oct 16 07:35:31 tmm tmm[1120]: 01220001:3: TCL error: Rule poolpicker - while executing “HTTP::method”
Oct 16 12:30:50 tmm tmm[1120]: 01220001:3: TCL error: Rule poolpicker - while executing “HTTP::method”
Does anyone know what causes these errors? My best guess is corrupted packets, but the error is so generic I have no way to verify that. I couldn’t find much in the AskF5 KnowledgeBase either.
Thanks in advance,
Chip
I played around with your irule a little and had a little success with the following:
though I generally set this at the command prompt
example: bigpipe class valid_methods { \“CONNECT\” \“GET\” \“POST\” \“HEAD\” \“OPTIONS\” }
then set my call to it anywhere not needed to init in rule, but this is with your init in the rule
when RULE_INIT {
set sec_http_versions [ “0.9” “1.0” “1.1” ]
set sec_http_methods [ “GET” “POST” “HEAD”]
if { not [matchclass [HTTP::version] equals $::sec_http_versions ] } {
reject
} elseif { not [matchclass [string toupper [HTTP::method]] equals $::sec_http_methods] } {
reject
