Object Move and Rename - Virtual Server, Pools and Nodes - under TMOS vers. 13.1 and ver. 14.1
I would like to know if the bug K08689048: The TMM service may produce a core file and restart when executing the tmsh mv command (https://support.f5.com/csp/article/K08689048) is fixed under 14.1 TMOS LTM version.
I have searched the version Release Notes but wasn’t able to find any concrete/direct reference.
Would like to know if there’s already experience here in the Forum on this specific topic.
I just did it in Ver 13.1.1.4 and the issue happened.
I then tried in Ver 14.1.0.1 build 0.0.7 point release 1, the issue did NOT occur.
Hope that helps! If it does please up-vote and select this answer, it’d be greatly appreciated!
-Dylan
