NTLM issue
Hi all
I am using a pair of 9.2 BIG-IP to load balance internet traffic to 2 bluecoat proxies. Users are authenticated using NTLM.
We have an serious issue with this setup.
The NTLM authentication process use 4 packets t
Client BigIP Proxy
------ get www.google.com --->
<---------- 407 -------------
------ NTLMSSP_NEGOCIATE ---->
<----- NTLMSSP_CHALLENGE ----
------ NTLMSSP_AUTH ---->
<---------- 200 -------------
this sequence is a successful authentication.
But sometimes, we only get 407 and NTLMSSP_NEGOCIATE when we use the bigip. Users are then considered as anonymous and they can’t access any website.
This only happens when we go through the bipip.
Any idea ?
Have you try to open a support case ? This section is about iRule so you may not receive the expecting help since the reader may not be the best suited for this
If you want us to help you anyway i think some information like
-Virtual server definition
-Pool definition
Those information may be useful to see what may be causing this. Those configuration information are in /config/bigip.conf
