Notice messages seen in regards to Object not found for iControl REST Child Daemon
Hi Folks, I am getting below messages from F5; how shall I fix them?
Aug 2 06:01:59 DSAM-LB1 notice icrd_child: 10950,10958, iControl REST Child Daemon,WARNING,Object not found - /Common/diameter Aug 2 06:02:00 DSAM-LB1 notice icrd_child: 10950,10959, iControl REST Child Daemon,WARNING,Object not found - /Common/dns
Below objects are not found by daemon…
/Common/diameter /Common/dns /Common/external /Common/firepass /Common/ftp /Common/gateway_icmp /Common/http_head_f5 /Common/https_head_f5 /Common/imap /Common/inband /Common/ldap /Common/module_score /Common/mssql /Common/mysql /Common/nntp /Common/oracle /Common/pop3 /Common/postgresql /Common/radius /Common/radius_accounting /Common/real_server /Common/rpc /Common/sasp /Common/scripted /Common/sip /Common/smb /Common/smtp /Common/snmp_dca /Common/snmp_dca_base /Common/soap /Common/tcp /Common/tcp_echo /Common/tcp_half_open /Common/udp /Common/virtual_location /Common/wap /Common/wmi
Regards, Sameer
