Hello,
I have an LTM 11.2 and I am trying to configure an interface failover using the external monitor, in order for one interface if it goes down to trigger the failover to the other unit.
When I copy the script from “Interface Failsafe Monitor” from the forum into a file called interface_failsafe in the /config/monitors .Then I do a “chmod 754 interface_failsafe” as instructed in https://devcentral.f5.com/wiki/advd…nitor.ashx
After that, i go to the GUI to create an external monitor (Type external), i cannot see/select the file that was create in the “external program” drop menu option.
In ver10.x you select the path of the file and there no drop menu.
Please I need some help on how to fix this.
Why I am not able to select the file that was created? Note that in the drop menu there are two default options(two files), the same two files that are in the path /config/monitors, as far as i remember the names of the files are “sample_monitor” and “…”.
Regards,
George
