Not able to see cookie contents using curl command
I am not able to see the cookie contents using curl -k -ss -D- -o /dev/null -L -H ‘Host:host URL’ IP/. My device is BIG-IP LTM and its version is 12.1.2
Adding the "
-v
" parameter to cURL displays the header data (including the Set-Cookie headers inserted by the BIG-IP or by the real server)
