I have taken the config. backup on a APM device & downloaded the UCS file, but I am not able to see the APM configuration under the /config/bigip.conf file when opening the UCS file in WinRAR. The version I am using is 11.4.1 is there something different in this version.
Do you see APM configuration data in the bigip.conf file on the box?
let me check the same from ssh cli will update you…
OK, thanks.
