Not able to monitor our LTM+ASM from GTM using 'bigip' monitor
We are monitoring our LTM+ASM from GTMs using monitor as ‘bigip’, it was working but off late that it is not working for a particular HA of LTM+ASM. What port GTM uses under monitor as bigip. How can i check on LTM+ASM if it is running with bigip service?
Nuruddin, I’m not a GTM expert but bigip uses iquery on port 4353. See the following for help with troubleshooting iquery troubleshooting GTM iquery
Hope this helps,
N
