ASM doesn’t validate the destination port--just the protocol (HTTP and/or HTTPS) you configure objects for. ASM will be able to block illegal requests/responses which are set for blocking.
ASM is not still blocking bad requests, in the service port within virtual server settings is by our non-default https application port set to 9191 and the protocol set automatically to other. Could be this an issue?
Please find below the request diagram (the internal web application work on port 9191):
The configuration you have should work fine as far as the VIP side of things; the textual ‘Service Port’ is simply a human-readable version of the service port setting. Whether the traffic is interpreted & decrypted as SSL and/or HTTPS is down to the profiles you have attached to the VIP - and if ASM is inspecting traffic correctly then you know you have those right.
I think you need to look more in the direction of your policy settings within the ASM GUI, rather than the VIP configuration.
What happens when a request arrives which you believe should be blocked - does the ASM log any violations on the request?
