non case senitive match in http class
I currently use http classses to do redirects which used to be done in iRules. At the moment for the URI Path I use pattern strings and this has worked fine, however these are case sensative and I now need to all for a complete mix of upper/lower case characters in the URI. I assume the best bet is to use regex instead of pattern strings, but I cannot seem to get it to work. Can some kind soul our there provide me an example of a regex that would effectively do a non case sensative match on any given URI? Alternatively is there a way I can get the BigIP to convert whatever URI was supplied to lowercase? Apologies if this is a “noob” question. :slight_smile:
Regards,
Craig
Put (?i) in front of your regular expression. This will make it case insensitive. The period and star at the end are representative of any character “.” that is repeated 0 or more times “*”. Be mindful to choose regex when adding these. Too many times I have added a regex as a pattern and wondered why it was not working.
eg.
(?i)^/hellothere.*
Will match …
/heLLoTherehowareyou
/hellotherehowareyou
/HELLOTHERE
/HelLothereHOWAREYOU
Jarvil
Hi Jarvil,
thanks for the reply. I’ll give it a go. Would be nice if you could use iRules functions (ie) [string tolower] in the URI Path for pattern strings, but I suppose you can’t have everything. :slight_smile:
Regards,
Craig
Hi Jarvil,
just an update, it seems to work though I had to add a $ to the end of the regex or else it would effectively do a wildcard starting_with match.
For example
(?i)^/advisors would match *any* URI starting with /advisors regardless of case.
(?i)^/advisors$ would match /advisors only regardless of case which is what I need.
Many thanks for pointing me in the right direction.
Kind regards,
Craig
