Hello All,
I’m using BIG-IP as load balancer of cache servers. The cache servers has limitation on amount of bandwidth. I tried to define this limitation on BIG-IP but it seems it only support number of connections per node not the bandwidth. Do you know a way to define the bandwidth of each node in the BIG-IP LTM so when it exceeds the specified bandwidth then make it offline and don’t forward more request to that ndoe.
Thank you,
