node selection string from v 4.x to v 9.x
I need help with converting the node selection string
node(findstr(http_uri, “?ip=”, 4, ‘/’) + “:80”)
from the persistence tab on v 4.x to v 9.x. i know there is no selection in v 9.x, so i guees an iRule should be written. i have a problem with the last statement that would use the node provided in ?ip=.
Thanks,
Vasile
Hi Vasile -
Something like this should work in 9.2 (replacing POOL with the name of the default pool):
   set myNode [findstr [string tolower [HTTP::uri]] "?ip=" 4 "/"]
   if { ($myNodeIP ne "") and ([LB::status pool POOL member $myNodeIP 80] ne "down") } {
      pool POOL $myNodeIP 80
For the condition using LB::status, you will need to be running at least 9.2. In older 9.x versions, you can instead add an LB_FAILED event to catch that condition and load balance in the default pool instead:
   if { $myNodeIP ne "" } {
when LB_FAILED {
   LB::reselect
HTH
/deb
Hi deb,
i have 9.1.2 installed. i’ve tried to use the following:
set myNode [findstr [string tolower [HTTP::uri]] “?ip=” 4 “/”]
if { $myNodeIP ne “” } {
but it doesn’t work.
thanks,
vasile
Hello Vasile,
It would be helpful to get more detail on what wasn’t working and what errors you saw. You could provide any relevant errors from /var/log/ltm using the current rule, or add log statements to the rule to get additional debug information.
I believe there are a couple of minor typos in the rule which may have prevented it from working as expected. There was a missing close parenthesis and myNodeIP was originally set as myNode. Try this and see what the results are:
   log local0. "starting..."
   set myNodeIP [findstr [string tolower [HTTP::uri]] "?ip=" 4 "/"]
      log local0. "myNodeIP: $myNodeIP"
      pool http_pool $myNodeIP 80
   else {
      log local0. "myNodeIP was empty: (myNodeIP: $myNodeIP)"
when LB_FAILED {
   log local0. "LB failed!"
   LB::reselect
Aaron
