I have configured a virtual server with four pool members. I would like to monitor the number of the connection for each member. If the number of connection reach 1000, can I send email alert and make the pool member disable?
Hi Daniel,
If you have equal connections going to all four pool members then you could simply track the total connections on the virtual and block from there rather then disable a pool member.
The irule I had in mind is the following
http://devcentral.f5.com/wiki/default.aspx/iRules/HTTPSessionLimit.html
or
http://devcentral.f5.com/wiki/default.aspx/iRules/LimitConnectionsFromClient.html
For alerts you can go to the following
SOL3667: Configuring SNMP trap alerts to send email notifications
SOL3664: Configuring BIG-IP to deliver locally-generated email messages
And if you want to generate a message based on a custom log event, refer to SOL3727:
SOL3727: Configuring custom SNMP traps
I hope this helps
Bhattman
You could configure this by setting connection limits on the pool members under Local Traffic >> Pools >> Pool name >> Members >> member IP:port >> Connection Limit.
Aaron
