[continuing from an initial post, by Ravi]
Hi Ravi,
In response to your your reporting issues (no performance data displayed) with the F5 Management Pack, I would assume the following:
- your F5 reports are installed (i.e. you can access them but you see no data),
- you correctly enabled the performance rules (collection rules) for the statistics that you would like to gather (Click here for details on how to enable performance rules.
Do you see statistics collected in the Performance View associated with the device? If you do see performance stats collected in the performance view, and still no reports for the same stats (in the related F5 report), I would run an arbitrary non-F5 report first (in SCOM), to make sure data is at least getting collected from the OperationsManagerDW (data warehouse) SQL database, and your data warehouse runs true.
Let us know how this goes, and we’ll take it from there…
Thanks,
Julian
Hi Julian,
I have enabled the performace rules. I am able to pull reports like"Pool Members configured on Device" but not other reports related to Bandwidth and connections of LTM devices.
In state view performnace column is laso showing as “Not Monitored”. DO i need to chnage some thing at F5 ens. Please let me know. Can you please send me sql query to check data in warehouse database.
ravi
HI,
Can you please help me in collection performance data. I followed F5 document to enable performnace and collection rules but still no luck.
With Regards
Ravi
Hi Ravi,
Here are some sample SQL queries that you can run against the SCOM live operations database (default: OperationsManager) and data warehouse (default: OperationsManagerDW), to find out if any of your stats have been collected (as raw SQL data). Your SCOM environment may have different database names, make sure you use the appropriated ones in the SQL query.
Live data query (~OperationsManager):
* Get the stats from the live database
select
BME.FullName,
PCV.ManagedEntityId,
PCV.CounterName,
PDAV.SampleValue,
PDAV.TimeSampled
from [OperationsManager].[dbo].[BaseManagedEntity] BME with (nolock)
join [OperationsManager].[dbo].[PerformanceCounterView] PCV with (nolock) on BME.BaseManagedEntityID = PCV.ManagedEntityId
join [OperationsManager].[dbo].[PerformanceDataAllView] PDAV with (nolock) on PDAV.PerformanceSourceInternalId = PCV.PerformanceSourceInternalId
where BME.FullName like 'F5.%'
Data warehouse query (~OperationsManagerDW):
* Get the stats from the data warehouse
select
PR.ManagedEntityRowId,
ME.ManagedEntityGuid,
PR.SampleValue,
PR.DateTime,
ME.FullName,
R.ObjectName,
R.CounterName
from [OperationsManagerDW].[Perf].[vPerfRaw] PR with (nolock)
join [OperationsManagerDW].[dbo].[PerformanceRuleInstance] PRI with (nolock) on PR.PerformanceRuleInstanceRowId = PRI.PerformanceRuleInstanceRowId
join [OperationsManagerDW].[dbo].[PerformanceRule] R with (nolock) on PRI.RuleRowId = R.RuleRowId
join [OperationsManagerDW].[dbo].[ManagedEntity] ME with (nolock) on PR.ManagedEntityRowId = ME.ManagedEntityRowId
where ME.FullName like 'F5.%'
Let me know if you get any results by running these queries. Watch for your specific stats (~bandwith, etc) if they show up.
Thanks,
Julian
