No interface available to add to trunk.
Hi All,
Good day,
I am new to BIG-IP and I just installed the LTM Lab.
Now I am checking on trunking the internal and external interface but I am unable to see any interface in the available section.
Regards, Ruchit
I see that all your interfaces has been assigned to VLANs (column VLAN Count in the 2nd screenshot). You cannot add interfaces to a trunk if they are already assigned to VLANs. You must delete the two interfaces from their respective VLANs, then create the trunk with both of them, and then add the trunk to each of your two VLANs.
