No held transaction to sink.
I am seeing following warning messageon LTM : any ideas what it could be ?: tmm[7930]: 01480001:4: No held transaction to sink.
nothing on askf5, nothing on google (except this question) so contacting support would be the next thing i would do.
you may open a case to verify if it is a bug 400693. anyway, it should be only warning message (i.e. no impact).
Bug 400693 - “No held transaction to sink” warning message when ASM blocks 100-continue transaction
We are seeing the same error message…any ideas or movement on this issue?
We got the same issue (running 11.6.0HF5) and I did open a support ticket to confirm it is bug id 400693. This is what the support engineer told me:
The message “No held transaction to sink” is comestic and you can safely ignore it.
The meaning of the message is as follows: When ASM blocks an illegal transaction, ASM will put a blocking page in place of the transaction. It has to wipe the transaction it holds (which it called “sink”) and starts a new transaction which will be the blocking page. In a 100 continuous blocking transaction, for some reason, ASM thinks that it does not have to “sink” anything since the headers are already released to server. […]
Based on past cases, this message is known not to affect service traffic. So again, This comestic bug id is 400693 and you can safely ignore it.
thank you Torsten. for others reading this in the future, make sure your situation is identical before accepting this is the solution and if you can contact support.
