No clientside connection established
I’m running 12.1.1, vCMP.
I’ve created a basic iRule that I’ve attached to a UDP VS:
rule log_udp_conn_details {
 when SERVER_CONNECTED {
  log local0.alert "[virtual] - [IP::client_addr]:[UDP::client_port] -> [clientside {IP::local_addr}]:[clientside {UDP::local_port}] ::: [serverside {IP::local_addr}]:[serverside {UDP::local_port}] -> [IP::server_addr]:[serverside {UDP::remote_port}]"
and now, I’m getting in /var/log/ltm:
Nov 3 10:02:14 XX-dc-5250v-1-vcmp-guest-1 err tmm1[17437]: 01220001:3: TCL error: /Common/log_udp_conn_details - no clientside connection established (line 1) invoked from within “IP::client_addr”
Within SERVER_CONNECTED event, is the clientside connection is not already established? Within UDP VS, at what event would clientside connection is established?
SERVER_CONNECTED is when the F5 establishes connection with the pool member.
Try using CLIENT_DATA or CLIENT_ACCEPTED as the event.
Bump… :slight_smile:
you can collect client side data in CLIENT_ACCEPTED and server side data in SERVER_CONNECTED:
when CLIENT_ACCEPTED {
   set sessionLog "[virtual] - [IP::remote_addr]:[UDP::remote_port] -> [IP::local_addr]:[UDP::local_port] ::: "
   append sessionLog "[IP::local_addr]:[UDP::local_port] -> [IP::remote_addr]:[UDP::remote_port]"
 log local0.alert $sessionLog
I was able to execute the iRule without any errors on my v12.1 BIG-IP system using a UDP virtual server. Can you show your virtual server’s configuration, please, so that we may see what profiles you may have attached?
Great… I was sure there was nothing wrong with it.
I don’t want to share the VS configuration, but I can tell you that it contains a RADIUS traffic profile.
Since this profile executes Message-based load-balancing (MBLB), I suspect it is the culprit. However, MBLB should only affect server-side, not client-side, so, I cannot account for the error I got.
The typical client-side/server-side connection flow that you see to with HTTP for example does not occur with RADIUS and other MBLB traffic. I don’t begin to know all the ins and out but I know it’s very different. There’s a great white paper by Lori McVittie here: https://f5.com/resources/white-papers/message-based-load-balancing
In the meantime, you might simply try saving the client info to a variable on the CLIENT_ACCEPTED event, then referencing the variable on the SERVER_CONNECTED event. I’m not sure if the mapping is accurate but… Something like this perhaps:
    set client_info "[virtual] - [IP::client_addr]:[UDP::client_port] -> [IP::local_addr]:[UDP::local_port]"
    log local0.alert "$client_info ::: [IP::local_addr]:[UDP::local_port] -> [IP::server_addr]:[UDP::remote_port]"
You shouldn’t have to worry about specifying the “clientside” or “serverside” contexts as the context is built into each event.
There’s a great white paper by Lori McVittie here …
It’s sort of superseded now by MRF, as per “Migrating MBLB Functionality to MRF Functionality” document. (Although MRF isn’t available for RADIUS, yet.)
However, again, the only question I want to know the answer to is - why the error. Either it’s intended or unintended consequence of MBLB.
