Many thanks for your reply, is preferred to have good knowledge for ( Docker - Containers - Kubernetes - AWS K8S) before start studying XC and NGINX Plus.
Hi @Mostafa_Elsayed that knowledge is not required immediately but eventually you will start to work with container workloads and K8s ingress so at some point you’ll need to get at least a bit familiar. Learning through using F5 Distributed Cloud and NGINX is a nice way to have context for learning!
Welcome to F5 @Mahek_Harwani , hope you are enjoying your internship! This roadmap is beginner friendly but I suppose that depends on the level you are starting at. There are additional videos across the DevCentral YouTube channel as well to explore.
