We currently have pools and nodes configured as follows, where there is one primary server and one secondary server.
The resulting load balancing algorithm is only really achieving a failover, where the primary server is always used, unless that has a problem, in which case the secondary server is used instead:
ltm node /Common/primary {
address PR.IM.IP.186
description "Server name is primary server"
ratio 65535
ltm node /Common/secondary {
address SE.CO.IP.186
description "Server name is secondary server"
ltm pool /Common/service_Pool {
load-balancing-mode ratio-node
members {
/Common/primary:80 {
priority-group 1
/Common/secondary:80 {
priority-group 2
min-active-members 1
monitor /Common/http
Please could someone advise me on how to have a number of primary servers and a number of secondary secondary servers.
In F5 config language, I am looking for the below, but don’t know what to set the ratio & priority-group numbers to and also if I need to have a different load-balancing-mode and min-active-members settings:
ltm node /Common/primary1 {
description "Server name is primary1 server"
ratio ????
ltm node /Common/primary2 {
address PR.IM.IP.187
description "Server name is primary2 server"
ratio ????
ltm node /Common/primary3 {
address PR.IM.IP.188
description "Server name is primary3 server"
ratio ????
ltm node /Common/secondary1 {
description "Server name is secondary1 server"
ratio ????
ltm node /Common/secondary2 {
address SE.CO.IP.187
description "Server name is secondary2 server"
ratio ????
ltm node /Common/secondary3 {
address SE.CO.IP.188
description "Server name is secondary3 server"
ratio ????
members {
/Common/primary1:80 {
priority-group ?
/Common/primary2:80 {
priority-group ?
/Common/primary3:80 {
priority-group ?
/Common/secondary1:80 {
priority-group ?
/Common/secondary2:80 {
priority-group ?
/Common/secondary3:80 {
priority-group ?
Thanks in advance.
