I need help with a rule. I set some cookie values and compare them-this part is woking fine. If the cokkie check is valid, I then want to check the uri. If the uri starts with/contains agencyctr I want to re-write the uri and re-direct user to https://host/center/templates/welcome.cfm.
If it doesn’t contain /agencyctr allow through to Shared pool.
If cookie check fails send back to original site
Please forgive me, I am by no means a coder. I’m sure it shows!!
when CLIENT_ACCEPTED {
set ckname aac1
set ckvalue [IP::client_addr]
set ckdomain .mydomain.com
set uri [HTTP::uri]
set host [HTTP::host]
set new_uri /center/templates/welcome.cfm
set new_url $host$new_uri
if {[HTTP::cookie exists $ckname]} {
if { $uri != “agencyctr/welcom.cfm” } {
pool Shared
HTTP::redirect https://$new_url
HTTP::redirect “https://aac.mydomain.com$uri”
Thanks!!
Update:
I think I solved my own problem…
set ckname aac1
set ckdomain .alliedinsurance.com
set uri [HTTP::uri]
if { $uri contains “agencyctr” } {
pool Shared
HTTP::redirect “https://aac.alliedinsurance.com$uri”
Thanks!!
Thanks for the update on the variables. I thought I had to set them before using them later. Good to know.
Kind of a strange rule. In a different rule, I set this cookie value and then re-direct the user to this rule. In this rule I want to check the cookie value to make sure they came through the other rule. If they didn’t and the cookie value doesn’t match, kick them back! If it matches, let them through to the pool.
I will do some testing with this new rule to see how it goes.
Thanks again for your help!
