Newbie needs help with redirecting a pool
Hello everyone.
I really need some help with writing an iRule that when one pool’s nodes are not available, it will reroute to another pool.
In other words, if b2b_pool is down, then route traffic to b2b2_pool.
Any help would be so appreciated.
Thanks.
Hello lfuson,
You should be able to use priority groups within your pool configuration do accomplish this without using a rule:
Specifying priority-based member activation
http://tech.f5.com/home/bigip-next/manuals/bigip9\_2\_2/bigip9\_2\_2config/BIG-IP\_9\_2\_2ltm\_guide-05-1.html
-Aaron
