New Product of F5 Load Balancer
Dear Gurus,
My company has purchased new product of F5 Load balancer and i am totally new to it.
Can you please help me to configure this product.
On first step what should i do ?
I have console cable which i connect it to the console and other end of console RJ45 to my laptop lan connection.
Now what ?
Malik Adeel Imtiaz
is web-based training helpful?
Web-Based Training
Dear Nitass,
Thank you so much for your quick reply.
Is this free tranning or with fees. ?
I am looking into it. Please confirm that on which link i should follow.
Adeel imtiaz
Is this free tranning or with fees. ?it is free but it is basic one. anyway, i think it is good place to start.
Console to LAN won’t work. I’d suggest you configure the management IP via the LCD and then connect using the management network interface. Apologies if I’ve misunderstood. As well as the training I’d suggest;
For the network setup, see here: 404 Page not found | BIG-IP Documentation
For the LTM load balancing setup, see here: 404 Page not found | BIG-IP Documentation
There is also a good beginners guide here: DevCentral
Thanks.
How can i set the Management IP via LCD i mean i which option i should choose.
And after set the IP what will be the next step. Another thing which i noticed is when i check the Version of F5 Networks throuch LCD and it is 9.2.3. (Please also comment on this too)
Adeel Imtiaz
Adeel,
I can only endorse what Steve and Nitass have suggested. The free training should get you up and running. Of course askf5.com is another resource to use. The relevant Platform Guide will detail how to set up the Mgmt IP via the LCD screen. Basically - X button, System Menu, Management screen. You can then login via a browser to this address and license / provision / configure etc…
v9.2.3 - this is no longer supported anymore so you’d need to upgrade them too. Again askf5 will detail latest supported versions and upggrade paths. That is if your platform allows.
Hope this helps,
N
I have connected the F5 through cross cable Management Ethernet Port to my Laptop Lan Port and used Internet Explorer to connect the F5 now it is asking for Password i am using
admin / admin but it is not getting it. Is there any other way to rest the password.
Adeel imtiaz
Can you try root / default instead please?
Is this definitely a new device and/or ‘virgin’ installation?
Nops root/ default admin/admin i tried but no progress..
I suspect not, in which case we might need to go for password recovery. Please confirm.
Dear Steve,
The device is basically 2nd hand and from other department. And when i asked them to provide the password they said that they will try tomorrow if the they have the password they will provide.
Adeel Imtiaz
just in case you want to reset password.
sol3350: Changing system maintenance account passwords (9.x - 10.x)
Dear gurus,
I have reset the password :)..of root and admin through following link.
After that i have connected the F5 Load balancer through laptop Internet explorer and type the ip address through https://10.0.0.1 and press enter.
It as me login and password i gave Admin / Admin.
The console is open. And i am very Happy thank you so much guys for such a great support.
Now next i want to create two pools.(i said pools as a first user of F5 LB)
I have 2 Application Servers.
IP of Node 1 = 10.21.40.1
IP of Node 2 = 10.21.40.2
I have 2 Web Servers.
IP of Node 1 = 10.21.41.1
IP of Node 2 = 10.21.41.2
Now i want to configure the Application Server and Web Server with this Load Balancer.
Your kind help is needed.
Malik Adeel Imtiaz
Great news. As previously posted, I’d recommend you read through these;
Dear Steve,
Thank you again ..
Please confirm should i FIRST follow
1) NETWORK SETUP
2) LTM LOAD BALANCING
3) GOOD BEGINNERS
Steve please suggest the above numbering priority.
Adeel Imtiaz
Yes that order. You got me thinking about this so here’s a draft list I’ve just created which I might get around to tidying up at some point;
General configuration steps and order;
•Licensing
•Provisioning
•Local user accounts
•Remote authentication
•DNS, NTP etc.
•Other management stuff
•Security stuff
•Interfaces
•VLANs
•Self IPs
•Failover and Configsync etc.
•Nodes
•Monitors
•Pools
•Profiles
•Virtual Servers
Good list Steve - when I was setting up some new ones I mapped out a similar list (although where it’s gone now i don’t know).
Anyway, the only two additions to this list I had were Routes (we needed a specific route off the box for one pool member) and iRules (not always needed I grant you). Obviously iRules towards the end and Routes somewhere before Nodes.
Adeel - I’d go with the free WBT
N
Dear Steve,
Excellent man you are really great. :slight_smile:
Malik Adeel Imtiaz
@Nathan - thanks and thanks for the additions. I will try and mull it over a bit more and post an updated list soon.
@Malik - Thank you, happy to help.
