New problem with iControl
Hi guys,
In version 11.5 you have changed a lot in client-ssl profile and we have a lot of new options for example
set_certificate_key_chain_certificate_file set_certificate_key_chain_chain_file set_certificate_key_chain_key_file set_certificate_key_chain_members set_certificate_key_chain_passphrase
but only
get_certificate_key_chain_certificate_file get_certificate_key_chain_chain_file get_certificate_key_chain_key_file
how can get passphrase from certificate-key-chain object? in theory there is get_passphrase but seems to missing “objects” as a parameter
besides all certificate-key-chain return two lvl array and get_passphrase return only array of ProfileString
Am i missing something ?
Regards, Marcn
The passphrase should not be retrievable as it is encrypted just like user credentials.
If is encrypted - what the problem ? BTW - you can retrieve user credentials so why not cert one ?
