New Error: SplitterDistance must be between Panel1MinSize and Width - Panel2MinSize
All has been swell until I tried to use the app this morning:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.InvalidOperationException: SplitterDistance must be between Panel1MinSize and Width - Panel2MinSize.
at System.Windows.Forms.SplitContainer.set_SplitterDistance(Int32 value)
at iRuler.iRulerMain.viewStatus(Boolean bVisible)
at iRuler.iRulerMain.initializeEditor()
at iRuler.iRulerMain.iRulerMain_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ScrollableControl.WndProc(Message& m)
at System.Windows.Forms.ContainerControl.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.42 (RTM.050727-4200)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
iRuler
Assembly Version: 0.9.0.20
Win32 Version: 0.9.0.20
CodeBase: file:///C:/Documents%20and%20Settings/e488bc/Local%20Settings/Apps/2.0/3LBJ923N.E7O/J5HW0MQD.CKE/irul..tion_0bb200f0aec2b128_0000.0009_985d9dc4e98f3a27/iRuler.exe
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
ScintillaNET
Assembly Version: 1.0.2350.23701
Win32 Version:
CodeBase: file:///C:/Documents%20and%20Settings/e488bc/Local%20Settings/Apps/2.0/3LBJ923N.E7O/J5HW0MQD.CKE/irul..tion_0bb200f0aec2b128_0000.0009_985d9dc4e98f3a27/ScintillaNET.DLL
Microsoft.VisualC
Assembly Version: 8.0.0.0
Win32 Version: 8.00.50727.42
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualC/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualC.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Deployment
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Deployment/2.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
axfr18pi
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
