I have 2 servers that have the default Gateway as the Cisco Network switch and not the F5.
On the Pool, that i have created, i have enable an SNAT automap.
When i access the Virtual Server url i can access the server through it with no problems, however, when i look at the statisics i can see that both servers handle the request! one comes in the other sends it back!
If your still with me! is there something that i have missed?
looking at the statisics it has 3 connections, i see it connect to node 1, and then 2 connections out of node 2. and via versa
If i view the source of the webpage, it shows that it does Load Balance, but not every new request goes to the different servers. it seems to stick! is there a time limit to the amount of time you stay on a server
