Network question
Hi all, as I’m a system person and trying to understand more on the network side. As below I have setup the Mgmt, internal and external IP.
From my understanding, Public IP will come to the firewall and on the firewall it should have a rule to reach the Virtual Server IP. From the Virtual IP, it will follow the Pool Load Balancer setting which will point to the internal Application server.
If there’s a need to troubleshoot, will the internal and external IP play any part ? My thinking was that the internal IP is communicating to the internal application servers.
eth0
Link encap:Ethernet
HWaddr xx:xx:xx:xx:xx:xx inet addr:10.1.9.15
Bcast:10.1.9.255 Mask:255.255.255.0
eth1
Link encap:Ethernet
HWaddr xx:xx:xx:xx:xx:xx inet6 addr: fe80::250:56ff:fe84:f50/64
eth2
Link encap:Ethernet
HWaddr xx:xx:xx:xx:xx:xx inet6 addr: fe80::250:56ff:fe84:69d1/64
external
Link encap:Ethernet
HWaddr xx:xx:xx:xx:xx:xx inet addr:10.1.7.29
Bcast:10.1.7.255 Mask:255.255.255.0
internal
Link encap:Ethernet
HWaddr xx:xx:xx:xx:xx:xx inet addr:10.1.8.29
Bcast:10.1.8.255
Mask:255.255.255.0
Of course, the first thing that comes into my mind is that the internal and external IP will play part in routing troubleshoot (connectivity troubleshoot).
If there’s a need to troubleshoot (like running tcpdump), the client side will be ==> < virtual ip >
While serverside will be
Or if using “SNAT automap”
It depends on the complexity of whats in place.
When I’m diagnosing faults on live F5 devices. We often filter on Destination Host, or Source Host. With a combination of ports.
However in some circumstances, we capture on another device on the Snat’d address.
Hmm that comment didn’t come out as expected :slight_smile: the client side will be ==> < virtual ip > While serverside will be ==> or (if using SNAT automap) ==> Or if using “SNAT automap” ==>
