This is my first post and i’m having trouble with a network forwarding VS configuration.
This is the scenario.
ServerTSM ServerMonitor
192.168.8.180/25 192.168.8.190/25
VRRP Gateway
192.168.8.250
ExtVLAN
192.168.8.240/25
LTM
192.168.9.120/26
IntVLAN
TSMClient
192.168.9.70/26
There are other VSs configured, but not affect this traffic.
LTM Default Gateway: 192.168.8.250
TSMClient Default Gateway: 192.168.9.120
Default routing behavior.
I need to pass traffic from the external VLAN to the internal VLAN for Backup & Restore traffic (IBM TSM) and monitoring (SNMP) - Administrative Purpose (Telnet, SSH).
So i decided based on F5 literature, that a Network Forwarding VS was the most suitable solution, but it did not work.
So i did capture traffic to see what was happening. My surprise was that ICMP traffic came and went without any problems on the external VLAN servers, but for some reason, snmp, ssh, telnet traffic, coming through the external VLAN to LTM, exit to the internal VLAN, but did not return any response.
is correct to thinkthat theNetwork Forwarding VScan solvethis requirement,and if so, whatparameters should I look?
for some reason, snmp, ssh, telnet traffic, coming through the external VLAN to LTM, exit to the internal VLAN, but did not return any response.was it syn packet? what bigip platform are you using? if it has pva chip, pva has to be disabled before.
sol6546: Recommended methods and limitations for running tcpdump on a BIG-IP system
Yesterday I tried the Host Forwarding instead of Network Forwarding and after making some troubleshooting, we find that the local Firewall on the client machine was preventing the return of answers to some protocols and IPs, including the forwarding IP.
So, I guess that the local Firewalls of the other clients were preventing the Network Forwarding VS receive the response.
