Network connectors types ?
Hi All,
Lets suppose we have two virtual networks in a site and they are of type “site local inside” or even if they are global. As mentioned in F5 documents virtual network is a kind of VRF where the end points are isolated on L3 level. So what network connector type can be used to connect both networks ?
Because in this document “Create Network Connector | F5 Distributed Cloud Technical Knowledge” the only three options that we can use are mentioned in below snippet
Hey @usmansa1 - I’m going to move your question into our Distributed Cloud Users group forum - may get a few more specialist eyes on this one there.
Thanks!
