Problem this snippet solves:
The following is an example how powerful the LTM in terms of hosting web pages w/o the necessity of having a physical web server. This technique can sometimes save you from purchasing or taking up valuable resource on a production web server for hosting a webpage.
This particular iRule throws up a network calculator which was coded by Al Vonkeman (http://www.subnetmask.info./)).
NOTE: The website does initially load up slowly. Thereafter it performs quickly as the processing is client side.
Code :
if {[HTTP::uri] eq "/calc" } {
set response {
<meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"><link rel="STYLESHEET" href="https://community.f5.com/t5/default.css" type="text/css"><title>Network Calculators</title><meta name="description" content="Free TCP/IP Network Calculators. Includes web-based Subnet, Supernet and network / node calculators."><meta name="keywords" content="subnet mask, subnet, subnet calculator, mask, supernet, subnet mask calculator, ip calculator, tcp, ip, TCP/IP, calculator, network, javascript, free,">
< SCRIPT type="text/javascript">
<!--- Hide script from old browsers
var code = 'unknown';
var version = 0;
var platform = 'Win';
var j = 0;
var i = navigator.userAgent.indexOf('MSIE');
if (i >= 0 && j == 0)
code = 'MSIE';
version = parseFloat(navigator.userAgent.substring(i+5, i+9));
j = 1;
i = navigator.userAgent.indexOf('Opera');
code = 'Opera';
version = parseFloat(navigator.userAgent.substring(i+5, i+11));
j = 1;
i = navigator.userAgent.indexOf('Mozilla/');
code = 'NS';
version = parseFloat(navigator.userAgent.substring(i+8, i+12));
if (navigator.userAgent.indexOf('Mac') >= 0) {platform = 'Mac';}
if (navigator.userAgent.indexOf('OS/2') >= 0) {platform = 'OS/2';}
if (navigator.userAgent.indexOf('X11') >= 0) {platform = 'UNIX';}
//alert(code+" "+version+" "+platform);
function initPage()
var f = document.forms[0];
if (f.elements.length)
if (GetCookie('oct1')!= null)
f.oct1.value = GetCookie('oct1');
else
f.oct1.value = 10;
if (GetCookie('oct2') != null)
f.oct2.value = GetCookie('oct2');
else
f.oct2.value = 0;
if (GetCookie('oct3') != null)
f.oct3.value = GetCookie('oct3');
else
f.oct3.value = 0;
if (GetCookie('oct4') != null)
f.oct4.value = GetCookie('oct4');
else
f.oct4.value = 0;
if (GetCookie('cf') != null)
var cf = GetCookie('cf');
f.cf[cf-1].checked = 1;
if (GetCookie('node') != null)
f.node.options.selectedIndex = GetCookie('node');
if (GetCookie('network') != null)
f.network.options.selectedIndex = GetCookie('network');
compute2(f);
if (GetCookie('dec1b') != null)
f.dec1b.value = GetCookie('dec1b');
else
f.dec1b.value = 0;
SetOrder();
if ((code == "MSIE" && version >= 4) || (code == "NS" && version > 3))
// document.CounterImage.src="http://fastcounter.linkexchange.com/fastcounter?112194+224395";
// document.Google3.src="http://www.google.com/logos/Logo_25wht.gif";
else
setTimeout("initPage();", 100);
function d2h(decimal)
var j=decimal;
var hexchars = "0123456789ABCDEF";
var hv = "";
for (var i=0; i< 2; i++)
k = j & 15;
hv = hexchars.charAt(k) + hv;
j = j >> 4;
return (hv);
function h2d(hex)
var j = hex.toUpperCase();
var d = 0;
var ch = ' ';
while (j.length < 4) j = 0 + j;
for (var i = 0; i < 4; i++)
ch = j.charAt(i);
d = d*16 + hexchars.indexOf(ch);
return (d);
function d2b(decimal)
var bit8=0,bit7=0,bit6=0,bit5=0,bit4=0,bit3=0,bit2=0,bit1=0;
if (decimal & 128) { bit8 = 1 }
if (decimal & 64) { bit7 = 1 }
if (decimal & 32) { bit6 = 1 }
if (decimal & 16) { bit5 = 1 }
if (decimal & 8) { bit4 = 1 }
if (decimal & 4) { bit3 = 1 }
if (decimal & 2) { bit2 = 1 }
if (decimal & 1) { bit1 = 1 }
return (""+bit8+bit7+bit6+bit5+bit4+bit3+bit2+bit1);
function d2bits(decimal)
var bits=0;
if (decimal & 128) { bits = bits + 1 }
if (decimal & 64) { bits = bits + 1 }
if (decimal & 32) { bits = bits + 1 }
if (decimal & 16) { bits = bits + 1 }
if (decimal & 8) { bits = bits + 1 }
if (decimal & 4) { bits = bits + 1 }
if (decimal & 2) { bits = bits + 1 }
if (decimal & 1) { bits = bits + 1 }
return (bits);
function snmcorrect(decimal)
snmcorr = decimal;
if (decimal > 255) snmcorr = 255;
if (decimal == 253) snmcorr = 254;
if ((decimal > 248) && (decimal < 252)) snmcorr = 252;
if ((decimal > 240) && (decimal < 248)) snmcorr = 248;
if ((decimal > 224) && (decimal < 240)) snmcorr = 240;
if ((decimal > 192) && (decimal < 224)) snmcorr = 224;
if ((decimal > 128) && (decimal < 192)) snmcorr = 192;
if ((decimal > 0) && (decimal < 128)) snmcorr = 128;
if (decimal < 0) snmcorr = 0;
return (snmcorr);
function b2d(binary) {
var decimal = 0;
while (binary.length < 8)
binary = "0" + binary;
if (binary.substring(7,8) == "1") { decimal++ }
if (binary.substring(6,7) == "1") { decimal = decimal + 2 }
if (binary.substring(5,6) == "1") { decimal = decimal + 4 }
if (binary.substring(4,5) == "1") { decimal = decimal + 8 }
if (binary.substring(3,4) == "1") { decimal = decimal + 16 }
if (binary.substring(2,3) == "1") { decimal = decimal + 32 }
if (binary.substring(1,2) == "1") { decimal = decimal + 64 }
if (binary.substring(0,1) == "1") { decimal = decimal + 128 }
return(decimal);
function bits2d(binary) {
var decimal = 0;
if (binary > 0) { decimal = decimal + 128 }
if (binary > 1) { decimal = decimal + 64 }
if (binary > 2) { decimal = decimal + 32 }
if (binary > 3) { decimal = decimal + 16 }
if (binary > 4) { decimal = decimal + 8 }
if (binary > 5) { decimal = decimal + 4 }
if (binary > 6) { decimal = decimal + 2 }
if (binary > 7) { decimal = decimal + 1 }
return(decimal);
function SetCookieValues(name, value)
var expDate = new Date(); // The expDate is the date when the cookie should expire, we will keep it for a year
expDate.setTime( expDate.getTime() + (365 * 24 * 60 * 60 * 1000) );
SetCookie( name, value, expDate);
function getCookieVal(offset)
var endstr = document.cookie.indexOf (";", offset);
if (endstr == -1)
endstr = document.cookie.length;
cookieval = unescape(document.cookie.substring(offset, endstr));
return unescape(document.cookie.substring(offset, endstr));
function GetCookie(name)
var arg = name + "=";
var alen = arg.length;
var clen = document.cookie.length;
var i = 0;
while (i < clen)
var j = i + alen;
if (document.cookie.substring(i, j) == arg)
return getCookieVal (j);
i = document.cookie.indexOf(" ", i) + 1;
if (i == 0) break;
return null;
function SetCookie(name, value, expDate)
var argv = SetCookie.arguments;
var argc = SetCookie.arguments.length;
document.cookie = name + "=" + escape (value) + "; expires=" + expDate + "; path=/" + "; domain=subnetmask.info;"
function DeleteCookie(name)
var exp = new Date();
exp.setTime (exp.getTime() - 1); // This cookie is history
var cval = GetCookie (name);
document.cookie = name + "=" + cval + "; expires=" + exp.toGMTString();
function ClearAll(f)
f.node.options.selectedIndex = 0;
f.network.options.selectedIndex = 0;
f.cf[0].checked=true;
f.oct1.value="";
f.oct2.value="";
f.oct3.value="";
f.oct4.value="";
f.snm1.value="";
f.snm2.value="";
f.snm3.value="";
f.snm4.value="";
f.snm1a.value="";
f.snm2a.value="";
f.snm3a.value="";
f.snm4a.value="";
f.snm1c.value="";
f.snm2c.value="";
f.snm3c.value="";
f.snm4c.value="";
f.snm1d.value="";
f.snm2d.value="";
f.snm3d.value="";
f.snm4d.value="";
f.snm1e.value="";
f.snm2e.value="";
f.snm3e.value="";
f.snm4e.value="";
f.oct1a.value="";
f.oct2a.value="";
f.oct3a.value="";
f.oct4a.value="";
f.oct1b.value="";
f.oct2b.value="";
f.oct3b.value="";
f.oct4b.value="";
f.hex1b.value="";
f.hex2b.value="";
f.hex3b.value="";
f.hex4b.value="";
f.bin1b.value="";
f.bin2b.value="";
f.bin3b.value="";
f.bin4b.value="";
f.nw1a.value="";
f.nw2a.value="";
f.nw3a.value="";
f.nw4a.value="";
f.node1a.value="";
f.node2a.value="";
f.node3a.value="";
f.node4a.value="";
f.nwclass.value="";
f.nwclass1.value="";
f.subsuper.value="";
f.nwquant.value="";
f.nodequant.value="";
f.snmbits.value="";
f.broad1a.value="";
f.broad2a.value="";
f.broad3a.value="";
f.broad4a.value="";
f.snmbitsc.value="";
f.dec1b.value="";
function Explain()
Explanation=window.open("network/explain.htm","Explanation","scrollbars=yes,resizable=yes,status=yes");
function Explain1()
Explanation=window.open("network/explain1.htm","Explanation","scrollbars=yes,resizable=yes,status=yes");
function Explain2()
Explanation=window.open("network/explain2.htm","Explanation","scrollbars=yes,resizable=yes,status=yes");
function listsubnets(f)
compute(f);
if (f.nwclass.value != "Illegal")
SubnetWindow=window.open("","SubnetWindow","scrollbars=yes,menubar=yes,status=yes,resizable=yes");
SubnetWindow.document.write("<h1>List of networks<\/h1>");
networks=f.nwquant.value;
nodes=f.nodequant.value+2;
SubnetWindow.status="Building Table";
if (f.subsuper.value == "Subnetted as")
var count=0;
if (f.nwclass1.value == "Class C")
SubnetWindow.document.write("<h3>for the "+f.nw1a.value+"."+f.nw2a.value+"."+f.nw3a.value+".0 network ");
SubnetWindow.document.write("with the subnet mask "+f.snm1.value+"."+f.snm2.value+"."+f.snm3.value+"."+f.snm4.value+"<\/h3>");
SubnetWindow.document.write("<table border=1>");
SubnetWindow.document.write("<tr><td rowspan=2 align=center><b>Network<\/b><\/td><td colspan=2 align=center><b>Hosts<\/b><\/td><td rowspan=2 align=center><b>Broadcast Address<\/b><\/td><\/tr>");
SubnetWindow.document.write("<tr><td align=center><b>from<\/b><\/td><td align=center><b>to<\/b><\/td><\/tr>");
nodes = ((256/networks));
for (var i=0; i < 256; i=i+nodes)
j=i+1;
topi = (i+nodes-1) & 255;
topj = topi-1;
if (networks == 128)
j = i;
topj = topi;
SubnetWindow.document.write("<tr><td>"+f.oct1.value+"."+f.oct2.value+"."+f.oct3.value+"."+ i +"<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+f.oct3.value+"."+ j +"<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+f.oct3.value+"."+ topj + "<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+f.oct3.value+"."+topi+"<\/td><\/tr>");
if (f.nwclass1.value == "Class B")
SubnetWindow.document.write("<h3>for the "+f.nw1a.value+"."+f.nw2a.value+".0.0 network ");
nodes = ((65536/networks));
for (var i=0; i < 65536; i=i+nodes)
count=count+1;
i4 = i & 255;
i3 = (i/256) & 255;
j=i4+1;
topi4 = ((i+nodes)-1) & 255;
topi3 = <div class="box">i+nodes)-1)/256) & 255;
topj = topi4-1;
if (networks == 32768)
j = i4;
topi4 = (i+nodes-1) & 255;
topj = topi4;
SubnetWindow.document.write("<tr><td>"+f.oct1.value+"."+f.oct2.value+"."+ i3 +"."+ i4 +"<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+ i3 +"."+ j +"<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+ topi3 +"."+ topj + "<\/td><td>"+f.oct1.value+"."+f.oct2.value+"."+ topi3 +"."+ topi4 +"<\/td><\/tr>");
if ((count == 256) && (networks > 512))
SubnetWindow.document.write("<tr><td>..<\/td><td>..<\/td><td>..<\/td><td>..<\/td><\/tr>");
i=65536-(count*nodes);
if (f.nwclass1.value == "Class A")
SubnetWindow.document.write("<h3>for the "+f.nw1a.value+".0.0.0 network ");
nodes = ((16777216/networks));
for (var i=0; i < 16777216; i=i+nodes)
count=count+1;
i4 = i & 255;
i3 = (i/256) & 255;
i2 = (i/65536) & 255;
j=i4+1;
topi2 = <div class="box">i+nodes)-1)/65536)& 255
topj = topi4-1;
if (networks == 8388608)
j = i4;
topj = topi4;
SubnetWindow.document.write("<tr><td>"+f.oct1.value+"."+ i2 +"."+ i3 +"."+ i4 +"<\/td><td>"+f.oct1.value+"."+ i2 +"."+ i3 +"."+ j +"<\/td><td>"+f.oct1.value+"."+ topi2 +"."+ topi3 +"."+ topj + "<\/td><td>"+f.oct1.value+"."+ topi2 +"."+ topi3 +"."+ topi4 +"<\/td><\/tr>");
i=16777216-(count*nodes);
if (f.subsuper.value == "Supernetted")
i=f.nw4a.value+1
j=f.broad4a.value-1
SubnetWindow.document.write("<tr><td>"+f.nw1a.value+"."+f.nw2a.value+"."+f.nw3a.value+"."+f.nw4a.value+"<\/td><td>"+f.nw1a.value+"."+f.nw2a.value+"."+f.nw3a.value+"."+ i +"<\/td><td>"+f.broad1a.value+"."+f.broad2a.value+"."+f.broad3a.value+"."+ j + "<\/td><td>"+f.broad1a.value+"."+f.broad2a.value+"."+f.broad3a.value+"."+f.broad4a.value+"<\/td><\/tr>");
SubnetWindow.document.write("<\/table>");
SubnetWindow.status="Done";
function compute2(f)
var cf = 1;
if (f.cf[1].checked=="1") cf=f.cf[1].value;
if (f.cf[2].checked=="1") cf=f.cf[2].value;
if (f.cf[3].checked=="1") cf=f.cf[3].value;
if (code == "MSIE")
var node=f.node.value;
var nw=f.network.value;
if (node > 0)
nw=0;
f.network.options.selectedIndex=0;
node=eval(eval(node));
else
var i = f.node.selectedIndex;
var node=parseInt(f.node.options[i].value);
var j = f.network.selectedIndex;
var nw=parseInt(f.network.options[j].value);
if (node > 0)
nw=0;
if ((nw == 0) && (node == 0)) nw=1;
var power2=2;
//Determine the class of network and calculate the subnet mask
if (f.oct1.value > 255) f.oct1.value=255;
if (f.oct2.value > 255) f.oct2.value=255;
if (f.oct3.value > 255) f.oct3.value=255;
if (f.oct4.value > 255) f.oct4.value=255;
if ((f.oct1.value > 0) && (f.oct1.value < 127)) f.nwclass.value="Class A";
if ((f.oct1.value > 127) && (f.oct1.value < 192)) f.nwclass.value="Class B";
if ((f.oct1.value > 191) && (f.oct1.value < 224)) f.nwclass.value="Class C";
if ((f.oct1.value < 1) || (f.oct1.value > 223))
f.nwclass.value="Illegal";
f.nwquant.value=0;
f.nodequant.value=0;
f.snm1.value=0;
f.snm2.value=0;
f.snm3.value=0;
f.snm4.value=0;
f.snmbits.value=0;
if <div class="box">f.nwclass.value == "Class A") && (cf == 1)) || ((cf == 2) && (f.nwclass.value != "Illegal"</div>
if (nw >= 1) node=16777216/nw;
var nwtemp;
if (node > 16777216) //supernetted
nw = 1073741824/node;
nwtemp = nw;
f.snm1.value=(~((64/nw)-1) & 255);
f.snm2.value=0;
f.snm3.value=0;
f.snm4.value=0;
f.subsuper.value="Supernetted";
nw=1;
else//subnetted
f.nwclass1.value="Class A";
nw = 16777216/node;
nwtemp = nw;
f.snm1.value=255;
f.snm2.value=(~((256/nw)-1) & 255);
f.snm3.value=(~((65536/nw)-1) & 255);
f.snm4.value=(~((16777216/nw)-1) & 255);
f.subsuper.value="Subnetted as";
power2=power2+6;
while (nwtemp > 1 )
nwtemp=nwtemp/2;
power2=power2+1;
f.nodequant.value=node;
f.nwquant.value=nw;
f.snmbits.value="/"+power2;
if (((f.nwclass.value == "Class B") && (cf == 1)) || ((cf == 3) && (f.nwclass.value != "Illegal"</div>
if (nw > 32768) nw=32768;
if (nw >= 1) node=65536/nw;
var nwtemp;
if (node > 65536)//supernetted
nwtemp = nw;
f.snm2.value=(~((16384/nw)-1) & 255);
f.snm3.value=0;
f.snm4.value=0;
nw=1;
else//subnetted
f.nwclass1.value="Class B";
nw = 65536/node;
nwtemp = nw;
f.snm1.value=255;
f.snm2.value=255;
f.snm3.value=(~((256/nw)-1) & 255);
f.snm4.value=(~((65536/nw)-1) & 255);
power2=power2+14;
while (nwtemp > 1 )
nwtemp=nwtemp/2;
power2=power2+1;
f.nwquant.value=nw;
if (((f.nwclass.value == "Class C") && (cf == 1)) || ((cf == 4) && (f.nwclass.value != "Illegal"</div>
if (nw > 128) nw=128;
if (nw >= 1) node=256/nw;
var nwtemp;
if (node > 256) //supernetted
nwtemp = nw;
f.snm3.value=(~((4194304/nw)-1) & 255);
f.snm4.value=0;
nw=1;
else//subnetted
f.nwclass1.value="Class C";
nw = 256/node;
nwtemp = nw;
f.snm1.value=255;
f.snm2.value=255;
f.snm3.value=255;
f.snm4.value=(~((256/nw)-1) & 255);
power2=power2+22;
while (nwtemp > 1 )
nwtemp=nwtemp/2;
power2=power2+1;
f.nwquant.value=nw;
f.snm1a.value = f.snm1.value;
f.snm2a.value = f.snm2.value;
f.snm3a.value = f.snm3.value;
f.snm4a.value = f.snm4.value;
f.oct1a.value = f.oct1.value;
f.oct2a.value = f.oct2.value;
f.oct3a.value = f.oct3.value;
f.oct4a.value = f.oct4.value;
f.oct1b.value = f.oct1.value;
f.oct2b.value = f.oct2.value;
f.oct3b.value = f.oct3.value;
f.oct4b.value = f.oct4.value;
compute(f);
compute3(f);
f.snm1c.value = f.snm1.value;
f.snm2c.value = f.snm2.value;
f.snm3c.value = f.snm3.value;
f.snm4c.value = f.snm4.value;
computeSNMA(f);
f.snm1d.value = f.snm1.value;
f.snm2d.value = f.snm2.value;
f.snm3d.value = f.snm3.value;
f.snm4d.value = f.snm4.value;
computeINV1(f);
if (((f.nw1a.value == 0) && (f.nw2a.value == 0) && (f.nw3a.value == 0) && (f.nw4a.value == 0)) || ((f.broad1a.value == 255) && (f.broad2a.value == 255) && (f.broad3a.value == 255) && (f.broad4a.value == 255</div>
f.nwquant.value=0;
f.snm1.value=0;
f.snm2.value=0;
f.snm3.value=0;
f.snm4.value=0;
f.snmbits.value=0;
SetCookieValues('oct1', f.oct1.value);
SetCookieValues('oct2', f.oct2.value);
SetCookieValues('oct3', f.oct3.value);
SetCookieValues('oct4', f.oct4.value);
SetCookieValues('node', f.node.selectedIndex);
SetCookieValues('network', f.network.selectedIndex);
SetCookieValues('cf', cf);
function compute(f)
if (f.oct1a.value > 255) f.oct1a.value=255;
if (f.oct2a.value > 255) f.oct2a.value=255;
if (f.oct3a.value > 255) f.oct3a.value=255;
if (f.oct4a.value > 255) f.oct4a.value=255;
if (f.snm1a.value > 255) f.snm1a.value=255;
if (f.snm2a.value > 255) f.snm2a.value=255;
if (f.snm3a.value > 255) f.snm3a.value=255;
if (f.snm4a.value > 255) f.snm4a.value=255;
f.nw1a.value = eval(f.snm1a.value & f.oct1a.value);
f.nw2a.value = eval(f.snm2a.value & f.oct2a.value);
f.nw3a.value = eval(f.snm3a.value & f.oct3a.value);
f.nw4a.value = eval(f.snm4a.value & f.oct4a.value);
f.node1a.value = eval(~ f.snm1a.value & f.oct1a.value);
f.node2a.value = eval(~ f.snm2a.value & f.oct2a.value);
f.node3a.value = eval(~ f.snm3a.value & f.oct3a.value);
f.node4a.value = eval(~ f.snm4a.value & f.oct4a.value);
f.broad1a.value = ((f.nw1a.value) ^ (~ f.snm1a.value) & 255);
f.broad2a.value = ((f.nw2a.value) ^ (~ f.snm2a.value) & 255);
f.broad3a.value = ((f.nw3a.value) ^ (~ f.snm3a.value) & 255);
f.broad4a.value = ((f.nw4a.value) ^ (~ f.snm4a.value) & 255);
SetCookieValues('oct1a', f.oct1a.value);
SetCookieValues('oct2a', f.oct2a.value);
SetCookieValues('oct3a', f.oct3a.value);
SetCookieValues('oct4a', f.oct4a.value);
SetCookieValues('snm1a', f.snm1a.value);
SetCookieValues('snm2a', f.snm2a.value);
SetCookieValues('snm3a', f.snm3a.value);
SetCookieValues('snm4a', f.snm4a.value);
function compute3(f)
if (f.oct1b.value > 255) f.oct1b.value=255;
if (f.oct2b.value > 255) f.oct2b.value=255;
if (f.oct3b.value > 255) f.oct3b.value=255;
if (f.oct4b.value > 255) f.oct4b.value=255;
f.bin1b.value = d2b(f.oct1b.value);
f.bin2b.value = d2b(f.oct2b.value);
f.bin3b.value = d2b(f.oct3b.value);
f.bin4b.value = d2b(f.oct4b.value);
f.hex1b.value = d2h(f.oct1b.value);
f.hex2b.value = d2h(f.oct2b.value);
f.hex3b.value = d2h(f.oct3b.value);
f.hex4b.value = d2h(f.oct4b.value);
f.dec1b.value = eval(f.oct1b.value*16777216) + eval(f.oct2b.value*65536) + eval(f.oct3b.value*256) + eval(f.oct4b.value);
SetCookieValues('dec1b', f.dec1b.value);
function compute4(f)
f.oct1b.value = b2d(f.bin1b.value);
f.oct2b.value = b2d(f.bin2b.value);
f.oct3b.value = b2d(f.bin3b.value);
f.oct4b.value = b2d(f.bin4b.value);
function compute5(f)
f.oct1b.value = h2d(f.hex1b.value);
f.oct2b.value = h2d(f.hex2b.value);
f.oct3b.value = h2d(f.hex3b.value);
f.oct4b.value = h2d(f.hex4b.value);
function compute6(f)
f.oct1b.value = f.dec1b.value >>> 24;
f.oct2b.value = (f.dec1b.value << 8) >>> 24;
f.oct3b.value = (f.dec1b.value << 16) >>> 24;
f.oct4b.value = (f.dec1b.value << 24) >>> 24;
function computeSNMA(f)
f.snm1c.value = snmcorrect(f.snm1c.value);
if (f.snm1c.value < 255)
f.snm2c.value = 0;
f.snm3c.value = 0;
f.snm4c.value = 0;
else
f.snm2c.value = snmcorrect(f.snm2c.value);
if (f.snm2c.value < 255)
f.snm1c.value = 255;
f.snm3c.value = 0;
f.snm4c.value = 0;
else
f.snm3c.value = snmcorrect(f.snm3c.value);
if (f.snm3c.value < 255)
f.snm2c.value = 255;
f.snm4c.value = 0;
else
f.snm4c.value = snmcorrect(f.snm4c.value);
bits=0;
bits=bits+d2bits(f.snm1c.value);
bits=bits+d2bits(f.snm2c.value);
bits=bits+d2bits(f.snm3c.value);
bits=bits+d2bits(f.snm4c.value);
f.snmbitsc.value = bits;
function computeSNMB(f)
if (f.snmbitsc.value < 0) f.snmbitsc.value = 0;
if (f.snmbitsc.value > 32) f.snmbitsc.value = 32;
f.snm1c.value=bits2d(f.snmbitsc.value);
f.snm2c.value=bits2d(f.snmbitsc.value - 8);
f.snm3c.value=bits2d(f.snmbitsc.value - 16);
f.snm4c.value=bits2d(f.snmbitsc.value - 24);
function computeINV1(f)
f.snm1e.value=~(f.snm1d.value) & 255;
f.snm2e.value=~(f.snm2d.value) & 255;
f.snm3e.value=~(f.snm3d.value) & 255;
f.snm4e.value=~(f.snm4d.value) & 255;
// end hiding from old browsers -->
| Network Calculators |
Subnet Mask Calculator | < script type="text/javascript"> | |
| Enter the TCPIP Network Address: | ||
| Force as Class: | Default Class A Class B Class C | |
| Enter the required number of sub-networks: | 1 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 32768 65536 131072 262144 524288 1048576 2097152 4194304 8388608 | |
| OR enter the required number of nodes/hosts per network (including network & broadcast addresses)***: | 2 4 8 16 32 64 128 256 512 1024 2048 4096 8192 16384 32768 65536 131072 262144 524288 1048576 2097152 4194304 8388608 16777216 33554432 67108864 134217728 268435456 536870912 1073741824 2147483648 | |
| Network Class: | ||
| Subnet Mask: | or | |
| Subnets: | ||
| Nodes/Hosts per Network (including network and broadcast addresses)***: | ||
Network/Node Calculator | ||
| Enter the Subnet Mask: | ||
| Enter the TCPIP Address: | ||
| Network: | ||
| Node/Host: | ||
| Broadcast Address: | ||
IP Address Converter | ||
| Enter the dotted decimal TCPIP Address: | ||
| or Enter the binary TCPIP Address: | ||
| or Enter the hex TCPIP Address: | ||
| or Enter the decimal TCPIP Address: | ||
Subnet Mask Converter | ||
| Enter the dotted decimal Subnet Mask | ||
| or Enter the number of bits in the subnetmask | / | |
Subnet Mask Inverter | ||
| Enter inverted Subnet Mask |
< SCRIPT type=“text/javascript”> } HTTP::respond 200 content $response “Content-Type” “text/html” } }
