i can see f5 get sessionid’s and add age correctly but LB not working properly, some times i can see f5 load balance connection to each server but sometimes not!!
i cleared all persistence records (b persist all delete) and connections (b conn all delete)
then i tested 5 new client machine each clients load balanced to same server
What can be problem , why this irule interest client ip and port ?
i didnt understand two lines in this code it start “debug”
In addition to Stefans helpful comments, it looks like you’re missing the section of the iRule where the response cookies are parsed for the ASP session ID. Without that, the second request would not be persisted to the same pool member as the first:
It looks like the three articles you linked to refer to a few different application errors. What is the actual error you see with two members in the pool? With the full codeshare example, do you see clients being correctly persisted? If you’re seeing persistence failures, can you change to source address persistence and see if the application errors are fixed? If so, it would seem the errors are related to persistence.
