Hi, I am trying to develop an iRule that will flow through several conditions, breaking out as soon as a condition is false to make it efficient. It doesn’t seem to be working but not sure why.
Here is what I have -
priority 150 when HTTP_REQUEST { if { [HTTP::method] equals “POST” } { if { [HTTP::uri] contains “/URI-In-Question/” } { HTTP::collect 100} if { !([HTTP::payload 100] contains “keyword”)}{ reject}
So the goal here is to test if the request is a POST and if not, stop processing. If the request is a POST, then check to match the URI. If the URI doesn’t match, stop processing. If the URI matches then grab the first 100 bytes of the POST payload and evaluate that payload for a keyword, if the keyword is not present in that first 100 bytes of payload, then reject the request, otherwise process the request.
The behavior I am seeing is very inconsistent and not what I am trying to achieve. I know I need to add some error checking and all that around content length but the basic rule isn’t working yet.
Any thoughts or suggestions?
Thanks in advance.
