Need urgent Redirect help!!!!
Hi all -
I have a problem here with redirecting the URL.
1. when users come in with http, the rule below needs to do a https redirect. This is working so far, however, when I try to add the following URL it is not redirecting to another pool.
This is working:
http://www.mysite.com → https://www.mysite.com
This is not working:
http://www.mysite.com/site1 → should get redirected to Pool “www_apache”…
I would like to add the “site1” redirection also to the same irule for the
https redirection below, but can not figure out how to do so. Please help!
Thanks!
HTTP::redirect https://[HTTP::host][HTTP::uri]
If all you’re trying to do is modify the above rule so that all mysite.com/site1 requests go directly to the www_apache pool, you’d want something like this:
  if { ([HTTP::host] ends_with "mysite.com") and ( [HTTP::uri] starts_with "/site1") } {
    pool www_apache
HTH,
Colin
Hi Colin,
Thanks for the quick reply…
What if I want to come in at http, get redirected to https first, and after that, i enter “site1” to the URL it should redirect me to
the www_apache pool still in the ssl session.
thanks!
Anthony
Oh for got also, I i want the following
/site2
/site3
/site4
to also use the “www_apache” pool how would I add this? Site1 through Site4 are on separate servers (apache servers), however the
original connection “http://www.mysite.com” is through the IIS servers.
Thanks,
Anhtuan
Well now you’re talking about two separate iRules, on two separate Virtual Servers.
On the port 80 virtual server you’d have the simple rule that you posted above:
Then you’d have another virtual server set up with the same IP address listening on port 443. That virtual server would then have an iRule assigned to it that would check to see if the URI started with site[1-4] and send them to the appropriate pool if that was the case.
Something like:
  switch -glob [string tolower [HTTP::uri]] {
    "/site1*" -
    "/site2*" -
    "/site3*" -
    "/site4*" {
      pool www_apache
Keep in mind that the Virtual Server listening on 443 will have to have a client SSL profile configured as well so that it can decrypt the traffic at the BIG-IP, otherwise it won’t be able to read the URI to route appropriately.
HTH,
Colin
Hi Collin -
The problem here is: I have two virtual servers called
“pool1_80” and “pool2_443”
Virtual server “Pool1_80” has a iRule for the httpS redirect if coming in over port 80. After encrypting with the client SSL, it sends it to server 10.1.50.11 and 10.1.50.12 in the pool respectfully.
However, if a user manually adds “/site1” after getting redirected to httpS, I get an http 1.1 error. If they successfully logged in this
session and click on a link “/site1” they should get redirected to another “www_apache” pool containing server 10.1.50.12 and 10.1.50.13 while maintining the SSL connection originally created by the first redirect rule created by the “pool1_80” virtual server…So
the “www_apache” server should see that the connection
and sessions came from the first pool and serve the
“/site1” page.
Thanks for the help thus far, but even if I tried to add the second iRule to the “www_apache” pool listening on port 80 and creating another “www_apache_ssl” with the same servers listening on port 443 as per your suggestion, it still does not work.
Please help.
Thank you!
