Need to upgrade OS v_11.5.2-HF2 to v_11.5.4
I need to upgrade v_11.5.2-HF2 to v_11.5.4 Need to use tmsh commands for - Implementation - validation - Rollback
“Never worked on OS upgrade before”
The exact commands will depend on if you also need to create a new HD/Partition for 11.5.4, or if you can override an unused install on another (currently inactive) partition. For a start, can you paste all output from command ‘tmsh list sys software volume’ (use code block please). Also, please specify your HA setup - do you have two units in Active/Standby pair? Regards,
You can use following command;
tmsh install sys software image volume HD1.x
make sure you do md5 checksum before installing the code to HD1.x volume. To check which HD1.x volume is available for installation use;
tmsh show sys software
It is Standalone.
Is there a reason to not use the WebUI if you are unfamiliar with the installation process?
In any case, I highly recommend reading the docs:
