Here are the settings as requested.
virtual seuk {
pool extweb01
destination 194.133.18.132:any
ip protocol tcp
profile http http {
basic auth realm none
oneconnect transformations enable
header insert none
header erase none
fallback none
compress disable
compress prefer gzip
compress min size 1024
compress buffer size 4096
compress vary header enable
compress http 1.0 disable
compress gzip memory level 8k
compress gzip window size 16k
compress gzip level 1
compress keep accept encoding disable
compress browser workarounds disable
compress cpu saver enable
compress cpu saver high 90
compress cpu saver low 75
response selective chunk
lws width 80
lws separator none
redirect rewrite none
max header size 32768
max requests 0
pipelining enable
insert xforwarded for enable
adaptive parsing enable
ramcache disable
ramcache size 100mb
ramcache max entries 10K
ramcache max age 3600
ramcache min object size 500
ramcache max object size 50K
ramcache ignore client cache control all
ramcache aging rate 9
ramcache insert age header enable
compress content type include
“text/”
“application/(xml|x-javascript)”
profile http http-acceleration {
defaults from http
ramcache enable
ramcache size 100mb
ramcache min object size 0
ramcache max object size 4194304
profile http http-lan-optimized-caching {
defaults from http
ramcache enable
ramcache size 10mb
ramcache max age 86400
ramcache max object size 2M
profile http http-wan-optimized-compression {
defaults from http
compress enable
compress buffer size 131072
compress http 1.0 enable
compress gzip memory level 16k
compress gzip window size 64k
profile http http-wan-optimized-compression-caching {
defaults from http
compress enable
ramcache enable
ramcache size 10mb
profile http seu_http {
defaults from http
oneconnect transformations disable
header insert “X_CLIENT_IP:[IP::client_addr]”
header erase none
fallback none
lws width 80
lws separator none
max requests 0
pipelining enable
profile http seuk {
defaults from http
