need to rewrite HTTP 200 status code to HTTP 503
Hello,
I am performing website maintenance and need to bring down our website for a few hours. I will be
serving a friendly maintenance page during this time. However, when Google comes by during the
maintenance period this will present a problem for indexing. I am running BigIP version 10.2.3
Google strongly recommends that we return a 503 HTTP result code during the maintenance window:
http://googlewebmastercentral.blogs…anned-site-
downtime.htmlhttp://googlewebmastercentral.blogspot.com/2011/01/how-to-deal-with-planned-site-
downtime.html
There are similiar posts to mine in these forums, but none resolve what I am trying to do. I want to
serve a maintenance page from a pool in VIP and have the F5 rewrite the result code from a 200 to a 503.
I am able to apply the iRule to the VIP, however, it does not serve my maintenance page. This is my
iRule:
HTTP::respond 503 noserver Retry-After: 10800
Thanks,
In your iRule you are sending a respond to the request so the LTM will not send the request to the pool. This pop up awhile ago to the iRule and did a small change so it should work in your setup.
when HTTP_REQUEST_SEND {
TCP::collect 12
when SERVER_DATA {
if {[findstr [TCP::payload 12] “200”] == “200”} {
TCP::payload replace 9 3 “503”
Hi Jason,
Do you see any errors in /var/log/ltm when you test that iRule? Are there other iRules or HTTP profile config options that might be sending a redirect? If so, you could disable all other iRules when you’re using the maintenance iRule using event disable all:
https://devcentral.f5.com/wiki/iRules.event.ashx
   event disable all
Aaron
Richard’s right and has a good example. I missed that you wanted to just rewrite the pool member’s status code.
There’s an existing Request For Enhancement for rewriting the status code using HTTP::status $new_status_code:
BZ385613 RFE: Make HTTP::status iRule command support writing data
You can open a case with F5 Support to add your request to the RFE and raise its visibility.
Aaron
Thanks much, that worked. I will also need to set the 503 ‘Retry-After header’ with something similiar to this:
Retry-After: Fri, 15 Jun 2012 13:00:00 GMT
Where would I put this ‘Retry-After header’ in the example you gave me.
Thanks,
Jason
In the HTTP_REQUEST_SEND you can add the header with the following command
if { [HTTP::header exists “Retry-After”] } {
HTTP::header replace Retry-After 10800
HTTP::header insert Retry-After: 10800
Thanks Richard,
Well, I added the ‘Retry-After’ code to my iRule and, while the iRule syntax accepted it, the maintenance page in the VIP is not accessible. I’ve posted my entire iRule. If I put the ‘Retry-After’ code anywhere else in the HTTP_REQUEST_SEND section, the iRule syntax will not accept it.
TCP::collect 12
when SERVER_DATA {
Can you post the error in /var/log/ltm. Most likely I over looked a syntex error whihc will cause the LTM to reset the connection and not display the page.
TCL error: iRule-Downtime503 - Illegal argument. Can’t execute in the current context. (line 1) invoked from within “HTTP::header exists “Retry-After””
Jun 14 16:04:18 local/tmm err tmm[7807]: 01220001:3: TCL error: iRule-Downtime503 - Illegal argument. Can’t execute in the curre nt context. (line 1) invoked from within “HTTP::header exists “Retry-After””
Ok it does not like the HTTP::header exists
I read through the WIKI and it looks like that is redundant all you have to run is the following
HTTP::header replace Retry-After: 10800
if the header is not there it will add if it is then it will update.
Sorry about that.
Richard,
Still not working. Here is the /var/log/ltm:
Jun 14 17:18:56 local/tmm1 err tmm1[7808]: 01220001:3: TCL error: iRule-Downtime503 - Illegal argument. Can’t execute in the current context. (line 1) invoked from within “HTTP::header replace Retry-After: 10800”
Here is the iRule:
TCP::collect 12
when SERVER_DATA {
What version are you running? The HTTP::header should be able to run the the HTTP_REQUEST_SEND event.
I am running version 10.2.3 Build 112.0. The iRule correct re-writes from HTTP 200 to 300 without this line:
However, as soon as I add that line to the iRule, the VIP will no longer serve traffic as mentioned above:
TCP::collect 12
when SERVER_DATA {
So, it appears that the HTTP_REQUEST_SEND is working.
Thanks for your help.
Ok let me test this out on my virtual LTM and see if I can get around this.
Ok I am a idiot there is two issues first HtTP_REQUEST_SEND should allow you to change headers but I think we have to be in server side context. The main problem is I told you to put the HTTP::header in HTTP_REQUEST_SEND. This is the event right before the LTM sends the request to the server side proxy. So this is the request to the server. When you need to change the response to the client. I fix the rule and ran it though some test and it seem to work and change the header. Again sorry for flipping the events
TCP::collect 12
log local0. “Added header”
when SERVER_DATA {
when HTTP_RESPONSE {
Richard,
It works, thank you. There is one more thing I’m hoping to do here. The 503 status text response is ‘HTTP/1.1 503 OK’. How do I get this to be ‘HTTP/1.1 503 Service Unavailable’?
Thanks.
If you want to change more data then you would have to do the following. Note it will over write more of the page from the pool member
TCP::collect 32
when SERVER_DATA {
if {[findstr [TCP::payload 32] “200”] == “200”} {
TCP::payload replace 9 23 “503 Service Unavailable”
