i have applied a default irule in http vs to redirect into https and also applied one more irule on https vs because some of the pages are still on http not in https when testing via debugger. now entire URL is redirecting everytime in https.
now how can i stop some of the page to be redirected in https? they should be in http only.
Can you post your redirect iRule? I’m willing to bet that you could change your redirect iRule to ignore certain URIs but seeing the actual iRule would help everyone troubleshoot.
Hi , below are both irules: one is applied on HTTP VS and another on HTTPS
Irule—applied in HTTP VS
when HTTP_REQUEST { HTTP::redirect https://[getfield [HTTP::host] “:” 1][HTTP::uri] }
Irule applied in HTTPS VS
when HTTP_RESPONSE { Check if response type is text if {[HTTP::header value Content-Type] contains “text”}{ Replace http:// with https:// STREAM::expression {@@} Enable the stream filter for this response only STREAM::enable } }
Alright cool. Yeah so just change the iRule on your HTTP VS to only affect specific URIs. Depending on how many different URIs you want redirected/not redirected it might be easier to add exceptions to either your HTTPS or HTTP traffic but it’s your call.
Here’s some pseudo-code.
if { [HTTP::uri] eq }
HTTP::redirect https://[getfield [HTTP::host] ":" 1][HTTP::uri]
