We wanted to redirect to a particular site when the url has /abc i implemented irule like the one below. It seems to work but the problem is its case sensitive. when client /ABC or /Abc except for the exact /abc it doesnt seem to work. we wanted to make it case in-sensitive. Kindly help me in this regard.
if { [HTTP::uri] ends_with “cgi” } {
pool cgi_pool
} elseif { [HTTP::uri] starts_with “/abc” } {
pool abc_servers
Regards
Siddharth S
surrounding the HTTP::uri with a “string tolower” command should do the trick. But, you’ll probably want to do it for each conditional statement. An alternative, and more optimal, approach would be to use a switch statement like this:
switch -glob [string tolower [HTTP::uri]] {
"*cgi" {
pool cgi_pool
"/abc*" {
pool abc_servers
The -glob option uses wildcards and is not as expensive as a regular expression check. Your alternative would have been something like this:
if { [string tolower [HTTP::uri]] ends_with "cgi" } {
pool cgi_pool
} elseif { [string tolower [HTTP::uri]] starts_with "/abc" } {
pool abc_servers
But, this does two string conversions to lower case. You could also store the lowercase uri in a variable
set uri [string tolower [HTTP::uri]]
if { $uri ends_with "cgi" } {
pool cgi_pool
} elseif { $uri starts_with "/abc" } {
pool abc_servers
Lots of options…
-Joe
Hi Joe,
Thanks for ur help. I used string tolower and its working successfully the way we wanted.
Thank u once again.
Regards
Siddharth S
