Need to create one irule to rediect uri abc.ra.well.com/portallogon(not actual uri) to the same uri with extention /irj/portal
I need to create one irule to rediect uri abc.ra.well.com/portallogon(not actual uri) to the same uri with extention /irj/portal. As of now I have to test it via one server and after successfully testing 47 more servers will be added. I can’t add this server in my pool( which is called in the VIP), so I think I need to create datagroup list for that server. I was trying to create one irule, below is the rule which I created as of noe.
when HTTP_REQUEST { check if this host is in the main datagroup if { [HTTP::host] equals “abc.ra.well.com/portallogon” and [HTTP::uri] equals “/” } { set newuri “/irj/portal” HTTP::uri “$newuri” set newurl [class match -value [string tolower [HTTP::host]] equals redirect_datagroup]
if the host is not found in the main datagroup, check the secondary datagroup
if {$newurl eq ""}
     check if this host is in the secondary datagroup that requires uri be included
    set newurl2 [class match -value [string tolower [HTTP::host]] equals redirect_datagroup2]
Can someone please help me to setup this irule.
if {$newurl eq ""}
    Sending again..
Hello,
Firstof be carreful do not mix up hostname, URI and URL
URL: abc.ra.well.com/portallogon
URI: /portallogon
hostname: abc.ra.well.com
set host [string tolower [HTTP::host]]
set uri [HTTP::uri]
if { [class match $host equals "host_datagroup"] and $uri equals "/" } {
    set newuri [class match -value $host] equals host_datagroup]
    HTTP::redirect "$newuri"
    return
In your datagroup you will have something like that:
string: abc.ra.well.com
Value: /irj/portal
If user access with the following URL: https://abc.ra.well.com/ it will be redirect to https://abc.ra.well.com/irj/portal
I hope that’s what you wanted. I did not test the irule. if you need other things light your need Regards.
