Need to Build a APM Portal for Client and have a dynamic resource assinged using Rewrite of URI
hope someone can help me understand how to build a APM Portal which uses dynamic resource assignment using a resource rewrite.
The server that they need access to is blocked by their local proxy and they will not allow it so i need to present them with an URI that is allowed like https://google.com/forms
but then have the APM do a resource rewrite to the URI below: https://server.ourdomain.com/programview.jsp
thanks in advance any insight or help anyone can give.
Sounds like you want Portal Access:
thanks for the document i followed it and built out the portal and the resource but cant seem to get authenticated. the document does explan the best way to authenticate users, i am currently trying to use LDAP. Any ideas?
