Need to apply regex to a variable
Hello,
I have a need for regex to find the 2nd occurrence of a character and capture the data until the end. I tested my regex here and confirmed this regex will do what I need it to “[^@]+$”. My issue is that when I test this via a simple irule the TCL regex doesn’t seem to work at all. Any pointers would be great.
when CLIENT_ACCEPTED {
    set $Login "jeff@test1@bank1"
    log local0. "TC login string is: $Login"
    set Result {regexp /[^@]+$/ $Login}
    log local0. "This is the parsed data $Result"
Expected result = bank1
