Need step-by-step guidance for migrating BIG-IP i2800 WAF to rSeries (UCS restore vs clean build)
Hello DevCentral Community,
We are planning a hardware refresh migration from a legacy BIG-IP i2800 running WAF/ASM to a new rSeries platform and would like to follow F5 recommended best practices.
Could you please advise on the step-by-step process for this migration, specifically around:
o Whether UCS restore is recommended versus building config fresh
o BIG-IP version compatibility considerations during the migration
o Interface/VLAN mapping differences between iSeries and rSeries hardware
o Best approach to migrate WAF/ASM policies and tuning after migration
o Common issues or lessons learned during real-world cutovers
Current environment:
" BIG-IP model: i2800
" BIG-IP version: 17.1.3
" WAF module: ASM / Advanced WAF
" Deployment: Active/Active
Thank you .
Hi @Blue_whale ,
there’s no black or white answer to your question.
With LTM&AWAF you could:
  • build a cluster between iSeries and rSeries BIG-IP tenant
  • do an UCS restore
  • build new
Depends on some factors like planned downtime, maintenance window.
My favorite way is to build a new cluster. Either from UCS with the platform-migrate option, or with automation. Or if the config is very small and LTM only, you could even do a migration with SCF file.
The new cluster requires to have managment port and HA&Sync VLAN to be connected. All other ports are disabled on the switch (or whatever upstream device).
On the cutover date, you just disable switchports on the old cluster, enable on the new - done.
If anything goes wrong, just rollback by disabling/enabling the port on the switch.
Works good with LTM and AWAF. Also with APM if not heavily customized.
Building a cluster with old and new might save you some headaches with complex APM setups.
But adds a lot of steps (complexity) with removing old and adding new cluster members.
And it doesn’t allow you the easy rollback option mentioned above.
Regarding your other questions:
  • Version compatibility:
    First migrate, upgrade afterwards. Keep your version!
  • Interface / VLAN config
    In rSeries VLANs and Interface are configured at the F5OS level. Mapped to the BIG-IP tenant. Self and Floating IPs are configured inside of the BIG-IP Tenant.
  • Best approach to migrate and tune ASM polices
    Migrate as described above. Tuning… I could give you a three day lecture on that.
    But it boils down to - keep it simple.
  • Common issues:
    You will forgot to migrate something. Legacy setting or whatever. :slight_smile:
Good luck
Daniel
Daniel provided a great guide!
Maybe the only thing I can add is to enforce all the learnings  or you may need to export them and import them in the new system
https://my.f5.com/manage/s/article/K80004017
Thank you for the detailed info .
I have few doubts :
#way is to build a new cluster. Either from UCS with the platform-migrate option >> Can we import UCS file from different Model ?Will it work ?
