Hi all:
I have an issue with getting my irule working…here’s the senerio..
BIGIP 2000 running software version: 4.5.13
Main URL: http://www.mydomain.com/blah/ --- THis should not be SSL
URL needing SSL: https://login.mydomain.com/blah/userlogin.asp --- points to the same back end web servers
problem:
When a user logins to http://www.mydomain.com/blah/ they should only get HTTP, however, when they click on a link when on the
main site, lets say the “login” link, they should then be redirected to the proxy for encryption, so the link needs to be changed to
below are my irule that i can’t seem to get working…
if (http_uri ends_with “blah/userlogin.asp”) {
redirect to “https://login.mydomain.com/%u”
else {
use pool APACHE_POOL
Please help!!
Thanks!
Anthony
