Need SSL connection Between client and F5
Need solution
I have set on URL in F5. Now they need SSL connection between Client and F5. Dont need SSL connection between F5 and backend serve.
Server is not the webserver.
Could you please let mw knoe the full process. How I will achive this.
To activate SSL on the client side, You have to configure an Client SSL profile first : Local Traffic ›› Profiles : SSL : Client
then you must add the created ssl profile within your Virtual Server.
You can find more help on 404 Page not found | BIG-IP Documentation
project dont have the SSL certificate. he needs CSR from loadbalancer then they request to certificate. Is that correct way to do ?
You can follow this procedure 404 Page not found | BIG-IP Documentation
or directly generate a CSR on the web interface of your BIG-IP : System ›› File Management : SSL Certificate List
You create a new SSL Certificate and make sure you select Certificate Authority in the issuer field.
Then you can download the CSR and send it to your CA Manager that will sign it.
Once you have the final certificate, you have to import it within your previously created certificate object on the BIG-IP.
Final step, you should create a new ssl profile that refer to the private key and certificate of your newly created SSL certificate object.
you can create csr from f5 or wherever you want. what you need are certificate and private key files.
