F5SJ
February 18, 2020, 10:17am
1
We have one VIp on port 25 in which we want to allow origin client ip. We asked server team to change the default route that will point to floating self ip of the VIP, that didn’t work.
I configured http profile on the VIP and enabled x-forwarder that didn’t work too. Kindly provide some solution to fix the problem.
VIP config:
ltm virtual xxxx {
description xxxx
destination x.x.x.x%RD:smtp
ip-protocol tcp
mask xxxx
partition xxxx
persist {
/Common/source_addr {
default yes
pool xxxx
profiles {
/Common/tcp { }
source 0.0.0.0/0
source-address-translation {
type automap
translate-address enabled
translate-port enabled
F5SJ
February 18, 2020, 10:19am
2
I searched some docs in devcentral and prepared one irule.
when CLIENT_ACCEPTED {
set c-addr [IP::client_addr]
log local0. “Client addr: $c-addr”
STREAM::expression {@^EHLO.*@@ @^HELO.*@@}
STREAM::enable
when STREAM_MATCHED {
set mstring [STREAM::match]
log local0. “STREAM_MATCHED: string: $mstring”
set replacment [string range $mstring 0 1]
append replacment “LO $c-addr\r\n”
log local0. “STREAM_MATCHED: replacement string: $replacement”
STREAM::replace $replacment
event STREAM_MATCHED disable
when SERVER_CONNECTED {
STREAM::disable
Will that work?
F5SJ
February 18, 2020, 12:16pm
3
Can someone pls update me on this..
