Need help with rewrite but can't use profiles :(
Love the community here and i am looking for a little help. To start off i only have APM enabled so i can’t use the LTM rewrite profiles. (really sucks). I need to create the following re-write:
https://field.test2.company2.com/bix-test/interface.aspx -> https://test.company.com/LegacyRequest/Interface.aspx
I have been toying with the following irule but i think i need a little help because i get page can’t be displayed.
when RULE_INIT {
   Log debug output to ltm logs - 1=yes, 0=no
set rwdebug 0
   Set up variables for the irule and sets the default behavior of the STREAM profile. .
  set chk_resp_rw 0
  set clientHost "field.test2.company2.com"
  set serverHost "test.company.com"
  STREAM::disable
   Below check if the http request is from the HOST and starting URI that requires the rewrite.
  if {[string tolower [HTTP::host]] equals $clientHost && [string tolower [HTTP::uri]] starts_with "/bix-test/"}{
                HTTP::header replace Host $serverHost
                HTTP::uri /LegacyRequest/Interface.aspx
                set chk_resp_rw 1
                if {$wdebug}{ log local0. "Host Rewrite: [HTTP::host] , Context URI = [HTTP::uri]"}
when HTTP_RESPONSE {
   Check server response for rewrites
  if {$chk_resp_rw}{
                 STREAM expression changes all references in the response payload with the desired rewrite
    if {[HTTP::header value Content-Type] contains "text"}{
      STREAM::expression @$serverHost@$clientHost@
      STREAM::enable
     if {$wdebug}{ log local0. "response Rewrite done: "}
                 Check Location header for desired rewrite
    if { [HTTP::header exists Location]}{
       HTTP::header replace Location [string map -nocase {$serverHost $clientHost} [HTTP::header Location]]
I have stream turned on, on the virtual server. Any advice would be great guys, thanks!
Let’s start with any error message from /var/log/ltm when you run this request.
With a fast review, I see this possible mistake (variable name declaration):
set rwdebug 0
But you are calling for
if { $wdebug }{ log local0. "…
So, it should be:
if { $rwdebug }{ log local0. "…
And maybe the:
should be just this:
HTTP::host $serverHost
I have not tested, so, I hope it helps.
Here is some of the errors from the ltm file
Nov  3 07:16:34 DCAK12F5A err mcpd[8848]: 01070151:3: Rule [/Common/benson_rewrite_irule] error: /Common/benson_rewrite_irule:14: error: [undefined procedure: /LegacyRequest/Interface.aspx&8221][/LegacyRequest/Interface.aspx&8221;]
Nov  3 07:17:44 DCAK12F5A err mcpd[8848]: 01070151:3: Rule [/Common/benson_rewrite_irule] error: /Common/benson_rewrite_irule:14: error: [unexpected extra argument "Uri"][HTTP::uri replace Uri &8220;] /Common/benson_rewrite_irule:14: error: [undefined procedure: /LegacyRequest/&8221][/LegacyRequest/&8221;]
